MKF
I know the wall shelf is the immediate thought BUT, hear me out and then please give me your two cents.
I have my Thorens TD160 on a pine tv cabinet that we have had for years. Also, on the cabinet is my Onkyo receiver that weighs about 60lbs, my cd player on its own shelf and my tape deck, also on its own shelf. The cabinet sits on large'ish circular feet that raises the cabinet off the floor about 4".
I live in an old house w/hardwood floors and have never had a problem with my Thorens re: footfall vibration problems. Until now. Same cabinet but, I moved it to a much more convenient area and, to be honest, significantly less foot traffic in its new area. But, clearly, this part of the room has more "bounce"/"spring" in the floorboards as the needle will bounce.
QUESTION....I know conventional wisdom is to get a wall shelf. This isn't possible as the wall isn't load bearing and it would be completely impractical on the wall that is loadbearing. I have placed some thick foam matting under the cabinet and you can barely see it. I have also put similar foam padding and 1" mdf under the Thorens. It is considerably better, but, will still needs more isolation.
So, back to the original description of my cabinet....would it help if I removed the feet off the cabinet so that it is resting with all weight on the floorboards? Or, do the feet help with the dispersion of horizontal/vertical vibration? My thinking is the weight of the unit completely resting on the floor with the foam pad still under may actually help.
Thoughts on the above?
Cheers in advance!
Cheers in advance!
