Hello AKers,
I am wondering the best way to hook up two powered subs to my second preamp variable output? First preamp variable output is of course running to my power amp. The 2nd preamp output is separate L & R channels. Should I run the left channel out to the left sub input using a y-connector subwoofer cable? And the right channel out to the right sub in using an identical y-connector sub cable?
Plan to balance the volume levels of both subs to the LR main speakers using a sound meter and test signals from my CD player.
Thanks,
BmWr75
Thanks,
BmWr75
