special_20
I have a Stereotech 1200. Over the winter it developed a hum on both the left and right channels. Hum is present:
DC offset is at 20mv (right) and 16mv (left). Note: procedure for and settings for DC offset and specs for DC offset are absent from manual; reading seem "within normal limits" per the DC offset sticky. There are no DC bias adjustments.
Hum seems generally volume dependent. Note: strangely on some positions of the volume pot, the hum seems to decrease and nearly go away. I did deoxit and thoroughly work the pot with no change in symptom (may be failing/degrading traces?).
I suspected it was the power supply issue. I have recapped both power supply boards and replaced filter caps (with the exception of a 470uf/80v which is still en route). All caps were same rated uf value as originals with upped voltage ratings. I fired up unit and tested with recap of each board. Hum is still there...
What are other potential culprits of 60hz humm? Power supply really seems to be the only "shared" source for a hum.
Is it possible for this to be transistors or diodes?
Any tips for checking dodgy grounds? Most grounds are soldered connections to case and look intact and are still shiny.
I have taken some readings on both boards. Board 04-4470 does seem to be showing some odd low voltages. Amp however seems to be functioning nominally.
- with no sources connected
- on multiple outlets and house electrical circuits
- on multiple sets of speakers and wires
- regardless of 2 prong plug orientation (again tested on multiple outlets and house electrical circuits)
