maxsmart
I am looking for input how to remove plastic from my ADS 1290 II midrange dome? :scratch2:
As you can see from the photo, the stuck surface area is about the size of a penny. This plastic is very thick, so from the little bit of careful pulling, the dome/speaker is in a dangerous situation. :tears:
I did use a hair dryer for a bit, but I sense the sticky material needs to get to a pretty high temperature to loosen up, plus the fact I can't see a way of getting heat equally distributed across the dome surface area.
Any and all input is greatly appreciated.
BTW - the midrange part number is 206-0215
