Sticky Tape
LoStrings
I have a question regarding some older reel to reel tape I have had lying around awhile. I am not sure, but I believe it is Ampex 456 tape, with the black backing. My question is: it has become sticky and leaves a buildup on everythng it touches. It actually caused some squeaking in play mode. Is this a problem with black faced tape in general or is it because it is just old tape? I have some older tape that does not have the black backing and it works great...it records good and runs very smoothly.
Some tape has sticky shed issues, Ampex 456 being among the worst ever. Ampex 406 is another well known for sticky shed.
Thanks for the information. I just noticed the sticky for sticky tape and read thru it. Now I understand what sticky shed can do to anything it touches.
Just had the problem,recorded on a radio shack 7 inch tape,hit rewind started than slow to a crawl.well crap my
Motor bad.well put an another tape on no problem. The shack tape slow rewind.so it does happen.so will store flat
Not on end , maybe that might help.
Greetings from RojoLand!
"…so will store flat - Not on end , maybe that might help." — That won't help the sticky-shed issue. That Radio Shack tape is probably ConcerTape, which is well-known for SSS (since it's reject Ampex tape for the most part). I had a reel of ConcerTape received brand-new around 1983 or '84, from a friend who used it just once to record some stuff for me. I played it back then, once. But in 2024 I tried to play it again, and found it was now doing an imitation of Scotch tape (the adhesive kind, not the recording kind!). So I sliced all that now-useless tape off the reel and binned it. Yes, I could have tried baking the tape, but it wasn't really worth the effort. The now-empty reel can be loaded up with fresh tape.
Take care,
J. E. Knox "The Victor Freak"
