That is what we came up with, sure, everyone who does EE/ME will come up with their own version. If you can find an easier/better/cheaper way, by all means, go for it.Did you ever consider rotating the Q1 - Q4 180 deg and scooting the their through holes towards the edge of the pcb? This would make it fit in the same footprint as the original STK. I'm using a gerber viewer that has a measuring tool and it seems that there is enough room. You could even add a second set of mounting holes to allow this possibility. I don't have access to gerber editing software or I'd try it myself. I may try on the pcb's I ordered by drilling out in the bare FR4 and sky wiring.
Another thought and something I have done before for removal of comps on PTH pcb's without damage, is to use a piece of bare Cu wire to bridge across all the device leads. This way you can have the soldering iron heat up all the leads at once, flow molten solder onto each lead and easily remove the device, After you can solder suck/wick the holes clean of solder for the new device to be fitted.1. With a double-sided through-hole board, pretty much impossible to desolder a component (destroy-to-remove is now in effect).
No one has stepped up to bat to offer a kit as the labor costs out way what most people are willing to pay.Will these be eventually sold in kit or assembled form? I have a 780 that I would love to do this to before the original packs fail.
The deal at pcbway is 100x100mm for $13.00 using the default process, of course not including shipping.I couldn't get the for $13 per 10 though
People are stupid, and do stupid things. The list of stupid things that the STK's in the 780 will not survive is a long one, hence the demand for the 0050 devices outstripped the supply of authentic original parts long ago.There are some of these units, like mine, with perfectly functioning power packs, that are still original. They are not all like ticking time bombs. I have a couple of sets of spares, but still, the panic set off by these things online is blown way out of proportion.
