I'm a noob re DIY on my system, so forgive any errors in my assessment below.
My 2 channel system is a McIntosh MA6300 running 2 Focal Chorus 720 loudspeakers. I listen to CD's, (Rotel) Vinyl (Linn)and stream music from the web via an Audio Engine Sender/Receiver.
About 2 years ago I started to notice that every so often, (not every time I listen) one of the channels (the issue doesn't seem to favour left or right) would start cutting in and out, or producing static like noise. I checked banana plugs and connections on the back of the Mac and the Focals, tightened everything up, moved the wireless receiver away from the rest of the system,and things seemed to get better.
But it wasn't fixed. The problem continued to happen off and on, but without any rhyme or reason. Then it would just go away.
I took the MA6300 in for repair, and of course they ran the system for 4 days straight with no issue. Brought it home, and it ran without the issue for about 7-8 months. then last week it started again.
I finally found others who have had the same problem, and their fix was a bad relay. I've opened up the MA-6300 with the intention of cleaning the speaker relay, but am unable to identify it. Can anyone here help? Is the relay "cleanable" or must I get it checked and replaced if necessary?
If anyone has suggestions of any kind I'd appreciate it. My brain is fried with just trying to figure this out.
Cheers,
Cap
Cheers,
Cap
