Hello forum! I've lurked here for a long time gathering useful knowledge during the time when my CT-F1000 was restored during a two year period. I finally got it back last fall, and it has worked flawlessly for a little more than six months now. Until yesterday.
The restoration process included:
-Clutch restoration from Markthefixer
-New pulley et al from WJOE
-New belts all over the place
-Full recap of the audio path
-Brand new pinch rollers
Now, like I said, the machine has worked flawlessly since October. A few days ago I noticed something was off as the auto-stop function stopped working even though the tape had reached its end. I didn't give it much thought, but it clearly was weird since it hadn't happened before. Then came yesterday when I tried to rewind a tape, and I immediately knew something was seriously wrong. After only a few seconds, the rewinding stopped, and also produced some tape slack as it did that. Weirdly, the tape counter didn't move during the short time the tape was winding. On the other hand, when I tried fast forwarding, the counter DID move, although the tape itself did NOT.
Anyway, I tried to play a tape and that worked. Being that I have two kids that need lunch, I walked off to the kitchen and let the tape play on in my living room. When I got back, the tape had finished playing, but the auto-stop had not engaged. About 15 minutes later the auto-stop DID engage, and the machine stopped.
But that wasn't the end. Now the machine wouldn't even play any more. It only took me a few seconds to figure out that the capstan motor wasn't running at all. When the switch is engaged as I put in a tape the ONLY thing that happens is the tape winds up the slack, but the capstan doesn't start.
I really can't for the world figure out how all of this would happen within 24hrs, on a machine that was working so well.
I know the tape-counter is a prime suspect here, as I think the auto-stop functionality is sensed from the movement of the counter. But why would that cause the capstan to give in?
I would really appreciate all your thoughts on this. At the moment all I'm doing is searching these forums to see if someone else has experienced something similar, but I think not
Thank you, Toby
Thank you, Toby
