Hi, tube folks !
Having run into strange problems I'm now have to call for community help.
I have built 40W PP AB1-class 6L6GC amp 485V B+ 5K, original Sansui AU-111 schematic and mod (made by someone in Japan) both attached. The guy from Japan built a power amp using original AU-111 transformers. I stayed upon original schematic (I kept RC 150pF + 22K in cathode of 6AQ8 which seem to help improve stability).
Since I did not have original Sansui AU-111 transformers, I used my own 60W unit, which also have 5K primary, separate CFB (same as original), 4/8 Ohm output (no 16 Ohm tap), and linear frequency response from 20Hz - 100 KHz. Amp is being powered by stabilized regulated power supply capable of 360 - 500V 0.5A. For a while I used 6P3S-E (40 mA idle current) and Shuguang 6L6GC (50 mA idle current).
First check I did with oscilloscope and generator. Amp is capable of 16 - 17V RMS output voltage (which corresponds to 36 - 40W of output power) on 8 Ohm load (50W resistor), very nice smooth looking sine-wave. Square-wave also seem to be good even on 10 KHz frequency. Unfortunately, I have single-beam oscilloscope and cannot compare two sine-waves side by side.
As it often happens during tests, once I have overheated the tube, and once even occasionally shorted two wires while measuring voltage (fuse was blown and PCB developed some burn marks).
I have cleaned PCB and replaced one of the 10 ohm cathode protection resistors which was seem to be measuring fine but looked strange due to the physically close location to recent short.
Now the problem. At relatively small signal level (several V) THD are 0.8% which is what it supposed to be (measured with RMAA and ESI Juli sound card), and IMD 1.8% (should be 1% or less). Unfortunately, once output level increases distortions also go unacceptably high. They are clearly visible on oscilloscope. What is really strange, 200 HZ/14V sine-wave looks perfectly fine, while 20 Hz is visible distorted crossing zero region (switching tubes ?).
Frequency response is +0.1/-0.12dB in 20Hz - 20 KHz range (look at the image attached, its perfect), noise level -94dB.
+1dB/-0.5dB peaks/dips above 30 KHz do not matter, not audible anyway.
Small overshoot/undershoot at square wave test is absolutely normal for big tranformer.
The first thing come into mind is to replace tubes what I of course did (I have tube tester so I can check them, all were OK). Second, it could be wrong polarity of CFB winding, but in this case it is not (amp oscillates if CFB connection polarity is wrong). Disconnecting CFB also yields no changes.
Suspecting power supply problem, I did the following. I disconnected amp from 6080-based regulated voltage stabilizer, and connected straight to the CLC filter (200 uF + 5H + 50uF). Then, I even removed 5H choke. Nothing changes.
Output transformer was another possible culprit - or to be precise, saturation of core at low frequencies. Reducing idle current of one of output tubes down from 50mA to 40mA, I got the following results at 20Hz:
Idle current VL1/VL2 --- V(out) --- W(out) --- Drop (dB)
I1=I2=50 mA --- 15V --- 28.13W --- (0dB)
I1=50 mA, I2 = 40mA --- 14V --- 24.5W --- (-0.6dB)
I1=50 mA, I2 = 33mA --- 13V --- 21.13W --- (-1.24dB)
Although distortions went visibly higher, output level dropped insignificantly, only -1.24dB. And this with imbalance which is simply huge by any means ! Thus, transformer core is very far from saturation.
Anyone have an idea what could be wrong?
Thanks in advance for any suggestion or help.
