Yes, right up to the edge of the cutout. Cover the screw holes, and stick a toothpick in them to help with alignment. Are you going to brace behind the cracks first?View attachment 1824256
Alright. Got the woofer out @Airjmax. Seems the crack does go all the way through...
Besides that, I suppose I put the caulk right where my screwdriver is pointing, and line the entire cutout?
Honestly, I never pulled Advent tweeters, because all the ones I had weren’t problematic. I suppose if the seal has been compromised, you should add some caulk.View attachment 1824307
Yep. Started that just now. Should I also lay down some of the caulk on the tweeters? I noticed some when I removed them, though they had eroded away due to age.
I'll start by resealing the cabinet that seems to be okay. Should I lay a thin bead of glue on the outside where the crack is exposed, or do you think it will be okayHonestly, I never pulled Advent tweeters, because all the ones I had weren’t problematic. I suppose if the seal has been compromised, you should add some caulk.
The bracing might tighten up the crack, but some clear glue on the front side might be best.I'll start by resealing the cabinet that seems to be okay. Should I lay a thin bead of glue on the outside where the crack is exposed, or do you think it will be okay
I placed some glue over the outer crack and it seemed to of repaired nicely. I think the resealing is a success as the speaker will 'bounce' back slowly.The bracing might tighten up the crack, but some clear glue on the front side might be best.
fairly moderate, not too loudSeems odd. I've never run a test tone that low through a finished Advent but I would think the tweeter would be incapable of producing that tone. How much volume are you running these tests at?
