streamer and amp recommendations under $2000 combined
SK_music
Hello,
I am new to buying audio equipment >$500/component. I’m overwhelmed by the choices online that one cannot listen to without ordering and possibily returning, but the limited choices within a total budget of $4000 at a local audiophile shop, where listening or borrowing for home trial is possible. I will put this system in a room of 9.5 x 9.5 feet or maybe 12 x 14 feet. I listen to classical, jazz, rock at moderate volume--usually at a volume one could talk over. I tend to like a slightly warm, not too trebly or bassy, sound, but still fairly clear or 'transparent.'
I bought Sonus Faber Lumina II Amator speakers and will get some decent used stands.
Now I would like to decide on the amp and streamer, and preamp if necessary, ideally for about $2000-2500 max.
Which Streamer?: wiim ultra ($329 +tax) or bluesound node ($549 + tax)? other?
The bluesound was recommended by the local audiophile shop and sounded good with Arcam and Sonus Faber speakers in the shop; but a friend/audio professional suggested staying away from bluesound.
Amplifier: Arcam Radia A25 ($1500 new, integrated amp) or a Parasound Halo A23 ($800 used; power amp)?
The local shop recommended the Arcam and the friend / audio professional recommended getting a used Halo instead of the Arcam.
If I get the Parasound Halo A23, will I need a preamp for streaming? or for occasionally playing CDs with a cheap DVD or blue ray player with digital output? Will I need a better external DAC (though I guess the Wiim and Bluesound have DACs in them)?
If I need a preamp and possibly external DAC with the Halo, what can I get for under $1200 combined that is/are good enough so that it/they do not undermine the quality of the rest of the system? In other words, what do I need to get to avoid putting a weak component in the system that makes all the other components sound significantly lower quality than what they are capable of.
thanks very much.
I’m using both Blusound Nodes and WiiM Pro streamers in my systems. To answer your question I’d recommend a WiiM Pro plus ($160), SMSL D6S DAC ($200), and the Yamaha S-501 integrated amp. ($550) Use the rest of your budget on a subwoofer, cables, and maybe a cd player or turntable if either interest you.
Hello,
thanks very much.
Are you going to stream only? Are you in the USA? If so here is what I recommend for a very good sounding streaming set up. I am a fan of separates, so…..
A WiiM pro streamer, $149 from Amazon, to a DAC (via optical cable or coax cable) in the $ 200 to $300 range. There are many choices such as the Geshelli standard J2 or a Schiit Modius or Modi multi bit along with a host of other brands in that price range. Then to a Schiit Saga 2 preamp, $279, it has a remote, passive setting (no gain) and a low and high gain settings. Then to an Akitika GT-104 amp or an Akitika GT-102 Z4 amp. The 104 is the fully discrete version and the 102 Z4 is the op amp version. Both put out between 50-60 watts per channel and are the 4 ohm versions. They are great sounding kit amps but he will build, test, and ship to your door for $625. Your speakers are 4 ohm. Add some inter connect cables, speaker wire and you are good to go for around $1600.
Of course, your local shop is probably the easiest way to get set up instead of ordering everything online.
I have started streaming internet radio using the Radio Garden app and an iPad 8 gen. connected to my amp using a 3.5 mm headphone jack to dual RCAs. Of course I could stream anything else, iPad connected by WiFi to an ERROS 6 pro network and an independent line fiber optic network (versus shared DSL line). Sound quality is excellent, and the variety of music is incredible. And then I have an iPad for many other uses.
Hello,
thanks very much.
As far as a new integrated, I would recommend the Yamaha A-S501. It is probably the very best combination of value, build quality, and performance available currently. Parasound makes great products. I have one of their pre-amps myself. Arcam, is also exceptional. As far as a streamer, I use a custom built multimedia computer. In fact, I am using it to write this right now. It is far more reliable and versatile than any "streamer". If you do not have experience building PCs yourself, have it built by a local (but competent) shop. The money spent here, is well invested as the audio (and video) performance will be on-par, if not superior. :)
I think it would be very hard to beat the Eversolo DMP-8 for streaming/DAC duty. Yes it is a bit more expensive but you really do not need a preamp as the DMP-8 has analog input. The addition of a quality DSP will prove very useful IMHO. You could still make it to a $2500 price range by using a couple of little Fosi V3 mono amps. Don’t laugh as they will drive your Sonus Faber speakers amazingly well. I recommend using balanced connection between them.
