I stream with Spotify.
And/or the rest of the system.
Edit: flipped the phone sideways so I can see your sig
Sorry, that was directed at the OP after they mentioned their sig.Not sure what my sig has got to do with anything; I don't have one, and it's not my system in question... I usually comment from a theoretical pov, because it avoids the whole 'revealing system' thing...
A different streamer or DAC will not improve Spotify sound quality, which is "lossy" (that is, Spotify uses files from which a portion of the content has been filtered out to make the file smaller).
The point was to dump Sonos for a different streamer.
If that's what you want to do, then the suggested Wiim is a good option.
But it is unlikely to improve your digital audio quality, since it does not seem to be an equipment limitation.
Well, that's purely subjective. And the OP probably doesn't want to go there in this thread.
Maybe what I have is the best I'm going to get? I keep hearing how digital music can be spectacular. I'm not sold. But then again, I'm not willing to roll the dice on a $ 5000 Sim Audio Moon streamer to find out, and ultimately be disappointed. I'd throw a grand at it, if someone could tell me that would work. So far, not so much.
Every component in your system, especially speakers, will determine what you can or can't hear. Only you can decide if you're willing to spend the time and money to experiment. For some, their systems are never good enough.
Try Qobuz or Amazon Music thru a Wiim. They both offer free trials, and as I said you can return the Wiim.
If that doesn't make you happy, then buying a more expensive DAC or streamer isn't going to either.
Vinyl, FM, Cd's, tape sound spectacular. Streamimg....ehhh
Try a different streamer in your system using Tidal HiFi or Quobuz and compare to your Sonos. If the streamer you try has an internal DAC, you can compare it to your D100's DAC to see which one you prefer. If you don't hear any improvements, send the streamer back and just keep what you have, or eliminate streaming as a source. Concentrate on what you enjoy.![]()
