Hey, looking for some help here as this thing is whooping my butt...
I have an ST-70 I am trying to get up and running properly, from what I've been told it worked just fine for a while then one day started "flashing then popping a fuse".... I've been going through and checking everything but I can't find anything major that would be causing this.
Basically, it'll turn on, run for a few minutes, then once the bias tops about 1-1.2v the rectifier tube will Arc and the fuse will pop.
I've tested with several rectifier tubes (as that was my initial suspicion) and they all exhibit the same behavior.
I've also tried different output tubes and get the same result each time. It also doesn't seem to want to act up on the variac
From my observations it would seem that:
The power transformer is of the new variety as the lamination stack seems taller.
The main filter is original, but tested fine.
Bias selenium has been swapped to a proper diode
The two 50uf caps tested off and were replaced.
The 10k ohm resistors test fine on the meter.
Power supply resistors are a bit off (around 10%) but I don't see a tolerance band.
The 15.6 ohm bias resistors test fine on the meter.
The 1k ohm grid Resistors test a bit high (10% or so).
The tube sockets have been reflowed.
Bias potentiometers tested for dead spots.
The resistors on the PC-3 board all were replaced at some point, looks like they did match the ones that needed to be matched with metal films.
The capacitors on that board have been replaced.
Starting to pull out my hair here...
