Im grateful I was a electronics and audio nerd from a very early age.
Therefor I was always looking at other folks stereo gear long before even being in the market to buy gear.
This exposed me to allot of different speakers and gear.
IMO I really think folks should try and hear as many different speaker designs as they can. As there are ALLOT
of different designs and sounds out there. Examples like, electro static, planar, full range drivers, transmission lines,
horn type, direct radiator, line array and many more. Easier said than done I know, but man do they all sound different.
I think this COULD at least lay the ground work for discovering what one prefers and what to build around. I own several
different designs and find each bring something unique to the table.
Also as others noted. Dont be afraid to spend a good deal of $ when the time comes. Clearly this comes with the caveat
of living within ones means. However Ive seen it and done it. Folks becoming obsessed with getting a “score” on something.
Rather than simply buying something they know they want at a fair price. And some times the “score” price is there for reason
(not exactly tip top). Yes sometimes only searching for a “deal” might keep some from ever discovering the next level.
Another factor I suspect is keeping ALLOT of folks from getting their system to sound just right. And or keeping folks perpetually
chasing the dragon of next level. Room treatment/setup. I know its been said quite a bit here and on other web sites. But its VERY true.
How gear is positioned in the room. Room acoustics. Tailoring the sound via all sorts of ways. This can make or break how potentially
great gear sounds and comes across. It goes way beyond bass response. Its also something I wish to continue to learn more about and execute.
One major factor I suspect folks also never discover how good their gear could sound is amplification. I know I will sound like a broken record.
Just it was a MAJOR eye opener how big a difference having a real amp with real power behind it makes even mediocre speakers sound FAR
better than they should. This will vary if folks are using super high efficient speakers (97db+ abouts) as they dont need much to open up. But those
make for a very small % of what most enthusiasts are using IMO. Im not trying to say all med range power receivers, tube amps, smaller watt Class A
amps so on dont / cant sound amazing also. And allot of it depends on how loud folks listen. Room size. Material listened to. So on… But I personally
feel ALLOT of folks would have a similar revelation to my own if they had the chance to hear their and other gear driven with a proper high power amp. IMO
Lastly, and this is a generalization, play around with things. I imagine allot of folks set it and forget it. And this can apply to all sorts of things.
Cables used, gain settings, media used, different play back devices, listening position, opinions of others, tweaks in general, so on…..
Just messing around with things can result in some amazing discovery. You never know till you try as is said.
The journey can and should be fun achieving the right sound. It has its pitfalls. And looking back on things I would avoid allot of my purchases.
But at least I learned along the way. And I know Im still learning and hope I always am.
