Dear all,
I hope everyone is doing fine. As I stated in the title, I have an Akai Clarity Series from my late father brought from Japan and recently I wanted to try it out but the turntable's (AP-M3) belt literally disintegrated. Never been replaced since 1984.
First thing I tried searching for the service manual and it doesn't exist. Some sites claims that they have but the previews are all for wrong models. I don't want to waste $20 for a wrong manual.
Then I tried to remove the platter by myself. Removed the mat, tried to lift from the holes didn't work. Gently tapped the spindle and lift at the same time didn't work. Applied some WD40 and waited couple of hours, nothing. Heated the platter and spindle gently didn't work.
Lastly, I opened it up. At the bottom removed the screws, nothing special, managed to get in. The spindle shaft hold by a "C" clip and also managed to removed that, still stuck. The platter spins without any effort, no issues there but I cannot replace the belt cause it doesn't want to come off. Can someone knows this model share some clues?
Thank you in advance, and apologies for the long post.
