whoaru99
Epic Member
Sorry for any highjack, but...
what, in general, is the best setting for your amp volume levels when paired with a preamp? In particular; I keep my B-2 speaker level pots straight up (half volume), which means my C-2a volume rarely goes over 10 o'clock. should the amp pots be set higher?
Personally, I'd set them even lower, but I guess that somewhat depends if you like to use the loudness contour to emphasize the low end at somehwat higher volumes.
http://www.audiokarma.org/forums/showthread.php?t=369992
