I put together a basic DIY record cleaning system yesterday. I modified the crevice tool of a vacuum and am cleaning with a solution of 25% isopropyl alcohol (99%), 75% distilled water, and a drop of dish soap. After cleaning and vacuuming a side, I went to play it and found that the stylus was getting gunked up part way through the first track. I cleaned and vacuumed it again and only made it to about the second track before it happened again. So I'm guessing that the vacuum is the problem here... At first it had too much suction and was lifting the record off the platter. I drilled some relief holes and that made it a little easier to spin, though it could still lift the record if I wasn't careful. Does anyone have any ideas on what could be wrong with my setup that is letting the gunk stay in the grooves? Also, should I be waiting in between applying the solution and vacuuming, or between vacuuming and playing? So far I've just done each step back to back and am not getting great results....Any help would be appreciated!
