I'm in Tampa FL. Switching base, Yes, I have some small heat shrink I can put on it before crossing them.
So far every other part of the radio works fine. Receive is fine, meter lights up and moves and all dials adjust fine. I'm even able to use USB and LSB/PA. PA when selected has the same results as transmitting. I have to have both gains at max in order to hear voice. There is static when key'd but I have all the gain up so I'm assuming that it's not being filtered out.
hFE question. If the current one is 160-320. I've not seen one that matches perfectly. My thought is to have one that is lower and higher to encompass the span but what if that could only be full range to make that happen?
Adding just a couple shots of it. I did unhook the side board so I could see under the wire bundle. The underside shows in the red where it was cut.
View attachment 2781344View attachment 2781349
