ChrisMarantz
I believe ecluser has this right, in that it's better to seek thermal feedback from the driver transistors instead of the output devices when you're working with a CFP output circuit. What is your experience with bias drift after the suggested modification?
The service manual for the 32 does not include any bias voltages. Using a watt meter to set the bias level is the only method described. I have found this method to be vague at best. The two units I have worked on had initial settings of around 15 watts per channel.
Having CR203 and Q207 in contact with the heat sink are not modifications, it's the way they came from the factory. My understanding of this design is that the two components provide feedback based on the temperature of the heat sink to maintain the bias voltage.
I use a 32 often and I have found that the bias setting - in watts- seems stable even after long and high output use.
You have provided the only bias voltages I have seen for this model.
