Maximillius
First off hi guys, the names Max and I've been a mechanic / diyer for about 10 years with a little car audio here and there. I know enough to install and wire full systems, but have never rebuilt a sub.
My question -
Recently I picked up 2 JL Audio W3 12" subs for dirt cheap ( 29$? Lmfao) at a local pawn shop that didn't know what they had.
Model 12w3v3-4, dual voice coil
One sub is fully functional, the other is blown producing NO SOUND. When you push down evenly on the sub it's semi loose and feels/sounds scratchy. I attached a pic -
So upon further inspection I found that the cone is actually unglued / disconnected from the spider/voice coil area, and if you lift up or press out you can see it's fully disconnected with a big gap between the two.
So - would this cause absolutely no sound seeing as how it's fully apart? Is this fixable? It seems like you should just be able to reglue it properly, I know it has to be aligned correctly ect.
Would be amazing if I could get this one up and running with the other one! Thank you in advance for any help!
My question -
