Suggestions for Make-Shift Dust Cover
finnbow
The Dude Abides
I'm the proud and pleased owner of a Pioneer PL-41 turntable that I received (free:yes:) without a dust cover. Any creative suggestions for an attractive make-shift dust cover. The plinth on this model is fairly large (20"x16") and maybe 4" high. I know I can have something custom made, but for now don't want to spend that kind of $$$.
Dude, what's your location? Include that info in your profile so that local AK members can provide assistance.:thmbsp:
To get the basic function on a dust cover; that is to keep dust off the platter mat---and my LPs by extension, I keep an old LP on the platter when not in use. For the rest of the deck, I just dust it every once-in-a-while.
This is actually my preferred method. I have a dustcover, but keep it packed away in an upstairs closet.
How about something with a little spousal appeal? (Yeh, I know. This throws a monkey wrench into this thread).
It would blow the budget to heck and back, but I was thinking about dust covers today. One made from vacuum-sealed double-paned glass, with the vacuum panels set into framing with ample silicone, along with rubber damping along the bottom edge, would probably provide more isolation than using no cover at all! You would still have the problem of internal reverberation from the stylus itself, though, unless you lined it with sound-absorbent material...but that would cost you transparency.
Short of that, for higher WAF on an absolute shoestring budget, you might make something from cardboard or other thin board, and cover it with an attractive scrap of cloth. Not transparent, but it would keep the dust off (remove it when using the TT) while --assuming you chose the cloth well-- better "blending with the decor" when the TT is not in use.
Short of that, can you DIY one from recycled plastic?
Dust covers that the spouse likes
Not trying to be funny but Tupperware comes in colors and women love it.
It also makes for a great dust cover if turned upside down
I wonder if it's the same pl41 that I robbed of it's dustcover? I used it's unusually large dust cover to make a nice custom one for my clear audio tt. I ended up giving the donor pl41 away to an ak member quite a while back. Hey stranger things have happened.
Referring to the link supplied by SpruceMoose, cutting and gluing plexiglas is one way of doing it.
Though I should note that Plexiglas can be bend easy (more or less) enough. I've only worked with smaller pieces, but I clamped it in between two pieces of wood at the point were I wanted it to bend. Then heated it with a heat gun (heat gun, like a hair dryer only much hotter). When it was hot and soft, I used another board to press it from behind and bent it over the first board.
You could cut the plexiglas or acrylic-glas into something of a 'plus' shape or a 'cross' shape, then bend that tabs over into a 5-sided box. Now you just need a way to close up the corners. Several possibilities come to mind, but really it just requires some ingenuity and imagination.
As an alternative, assuming you like the look, you can buy right angle or L-shaped wood molding in various materials (oak, pine, etc...). You could build a frame from this L-Shaped molding and glue flat pieces of plexiglas or acrylic-glas to the inside of the molding.
Between the molding, the glass, and the glue, it should hold together nicely.
The hinge is the hard part though. There are assorted woodworking shops that might have a hinge you could use, but I think it will be difficult to come by. Especially a hinge that allows the dust cover to be removed.
I think, for a hinge, the best you could hope for is a trashed out turntable that you could salvage the hinges from.
Though may turntables have dust covers that don't have hinges. In this case, just leave enough room behind the turntable to prop the dust cover against the wall until you are ready to put it back on again.
Just a few thoughts.
Steve/bluewizard
Calling my turntable trash, are ya? :nono: Seriously though, a close friend inherited this TT from a deceased Army officer who picked it up overseas years ago. It had been been sitting in storage for years - it still had the functioning original cartridge (~40 years old), but no dust cover.
Nope not calling your tt trash at all. They are well built tt's imho. I didn't think there were that many coverless pl41's around. Obviously it never belonged to me. I'm thinking either a diy cover or robbing another pl41 might be your best bets with the large size of the pl41 cover. Good luck
FinnBow,
Is that really your picture and are you the famous cowboy poet I saw on PBS?
Steve/bluewizard
Nope, this picture is of Sam Elliott, the beloved cowboy actor:
http://en.wikipedia.org/wiki/Sam_Elliott
My avatar is lifted from a scene in the bowling alley on the Coen Brother's 1998 movie "The Big Lebowski" where he played the movie's narrator. One of his classic lines is "the Dude abides." If you are at least slightly demented and enjoy the Coen Brothers, race to the video store and enjoy this cult classic.:smoke:
