dtone
Reached a troubleshooting dead-end (for me), so hoping to get some advice. Initially thought it might be a muting circuit problem (see other thread), but no dice.
Problem: Reliable 1990s era Roland GP100 unit that recently stopped producing sound from any of the outputs. Functions properly in every other way.
Background and troubleshooting done thus far:
- Note: Link to service manual
- Powered on the unit one day and was working as normal. Couple days later, a high pitched signal noise began (link to sound file). Note that the sound worsens as I change to a higher gain patch on the unit. Normally, the unit is silent when powered on and idle.
- Tried moving to a different outlets/circuits, but little to no change.
- Noise was present with or without guitar plugged into input. Would sometimes go away temporarily if the input volume was quickly adjusted up/down a few times.
- Noise worsened and became more prominent over the course of a couple days.
- Unplugged unit and removed cover to visually inspect inside. Saw nothing obvious - No burn marks on PCB, broken traces or terminals, etc. Very clean inside the unit.
- Detached Input Board (containing input jack and input volume pot) from volume knob/front plate and visually inspected (it remained connected to Main Board). Nothing obvious.
- Reassembled the unit.
- Sound output stopped completely. No noise or signal. Dead silent.
- Swapped Input Board Assemblies with another fully working GP100 unit. No change. Bad unit didn't work, good unit continued to work. Replaced boards back into their respective GP100 units.
- Swapped Power Board Assembly and transformer with another working GP100 unit. No change. Bad unit didn't work, good unit continued to work. Replaced board and transformers back into their respective original units.
- Swapped Main Board Assemblies with another working GP100 unit. Bad unit now worked perfectly. Other unit now exhibited the same no sound issue. So, something on the Main Board is faulty. Kept boards in their new units.
- Inspected Main Board again and reviewed schematic. Noticed some slight white corrosion on a transistor (Q50). Per the schematic, this is part of the Muting Circuit. Cleaned the transistor with alcohol/q-tip. Still no sound.
- Measured Q50, Q46, and Q47 in the muting circuit with DMM on diode setting. All measured as expected, except for Q47 which indicated non-conducting B-E and B-C. I removed both Q50 and Q47 from the board and re-measured. Q50 was fine. Q47 was still non-conducting on B-E and B-C, but turns out it’s a BRT (bias resistor built-in transistor), so the DMM voltage was too low to measure.
- Replaced both Q47 and Q50. Still no sound.
