Congrats, That's a great subwoofer and changed the game when it was introduced.Picked one up yesterday for $385 in good working. Rattles everything in my bedroom, truly flat to 18Hz. 440W Continous, 2.7kW Peak for 1/10 of a second.
I'm surprised the neighbors haven't knocked on our door yet, considering my father lives in an HOA.
You should see some youtube videos on the nightmares of being part of the HOA.Congrats, That's a great subwoofer and changed the game when it was introduced.
hoa= homeowners association. i.e. the debil.
Thankfully my father lives in a genuinely decent HOA. Great neighbors, quiet, no complaints in the past 3 years my father's lived there.You should see some youtube videos on the nightmares of being part of the HOA.
No thank you!![]()
I own a MK-IV. Was bought brand new.
Had lots of trouble with it...
Twice to Sunfire, ship the whole Sub, and neither of their repairs held up...
I then was able to ship just the Plate Amp to Mike Flannery, who used to work for Sunfire...
He replaced a total of 45 Caps on mine, and I had taken many before close up pics of the Boards, etc.
It appears he did precisely what he said he was going to do when I spoke with him by phone...
I too had Bill do some work for me and I agree he's a straight up guy that does super quality work.
So we fired up "Twilight: Breaking Dawn part 1" with the Sunnyfire and...we got a complaint from one of our friendly apartment neighbors as their floor and walls were vibrating in their apartment across the corridor from ours. It was also 10PM at night. I also noticed the sub had shifted direction when we received the complaint due to the fact that it's literally a monstrous beast in a tiny box, and was set on a hardwood floor.
Admittedly we had the receiver turned up to 78/100 (it's an Onkyo TX-SR602), and the sub turned up to the +15Db point via LFE, but I didn't feel like turning it down until that point. It was well overpowering the primary speakers on certain scenes though.
Not sure why my father or brother decided to turn it that high when setting up the sub, but I would certainly not be that kinda dumbo if I set things up myself.
So now I adjusted the volume on the sub to a significantly more reasonable level for apartment use, and it sounds much better now that it blends in with the Philips MCD-708 bookshelf speakers. The risk of annoying the neighbors has also been reduced (although this fourplex apartment building is rather well built on its own). I still need to get some stands for those speakers though - and to support the 45lb sub so it doesn't dance across the floor again
I will also mention that this is the first noise-related complaint that we got from a neighbor.
@Romeo Wolf This is all good solid information. You'd do well to follow it.You should be aware that most complaints about subwoofers being slow and/or boomy are because the level or crossover frequency are to high. Frequently it's both.
If you can hear that a subwoofer is in use it's almost always because it's too loud. If a subwoofer sounds boomy the crossover frequency is too high.
The only time a subwoofer should be noticed is when it's turned off. The lack of bass is easily noticeable.
Suggestions for setting up a subwoofer:
Set the crossover frequency at the -3dB point of the main speakers.
Set the subwoofer level so you can just barely hear it working. Then, turn it down a notch.
These two suggestions will get you close to what the entire system is capable of doing. To get even better integration you need an SPL meter and some test tones to measure things.
I usually suggest doing the subwoofer crawl to find the best location for it. However, that requires a lot of choices for placement.
