Shall I solder it back to its place? I removed the BNC input to improve heat outflow out from the DAC.That is the BNC input.
If you want to use the coax SPDIF input, probably...Shall I solder it back to its place?
I never used that input, but soldering it back to its proper place. I believe the BNC connector is a part of the ground circuit.If you want to use the coax SPDIF input, probably...
It will work without the BNC connected. I know because when I got my Maverick, the person before had removed the connections to the board for some reason.Shall I solder it back to its place? I removed the BNC input to improve heat outflow out from the DAC.
Without the BNC connector a DAC it is not any cooler. It is warm.It will work without the BNC connected. I know because when I got my Maverick, the person before had removed the connections to the board for some reason.
I reconnected it, but
I have not noticed that the Maverick generated excessive heat, which needed another hole to dissipate heat, but perhaps yours has that problem.
I had that thought, too. But then it crossed my mind that perhaps they meant that removing the BNCs added ventilation holes...The output jacks are just output connections, they don't
generate any heat in themselves at
Yes, I removed the BNC connector to improve ventilation inside the DAC.I had that thought, too. But then it crossed my mind that perhaps they meant that removing the BNCs added ventilation holes...
If you really need to dissipate heat, you could add a small fan to move some air, but I don't understand why the DAC is making excessive heat? Easy lastYes, I removed the BNC connector to improve ventilation inside the DAC.
But now I think about how ventilation is related to heat outflow.
The tube output stage?but I don't understand why the DAC is making excessive heat?
Maybe, can't really imagine anything else, but not a problem on mine. Tubes do get hot, but I don't think the tube in the MaverickThe tube output stage?
I wonder if you might have a capacitor going bad. Do any of the caps look bulging or different that the others. Since the hum/buzz is always there,I have a noise issue with my D2. I have done the Sparkos OpAmp upgrade and changed tubes. Got it hooked into my Yamaha A-S1100 amplifer.
I would describe the noise as a constant buzz/hum, gets worse and worse when i turn the volume on my amp up. At normal listening volume its not that obvious, but its there.
The noise is there regardless of tube or normal line out from the D2. Also regardless of input on the d2, and whether or not cd-player/streamer is powered. Other sources connected to my amplifier is not noisy (turntable, cassette deck etc).
So far I've tried the following, without any success:
-Changed input on my amp
-Changed cables, both rca and power cable
-Messed around with positions of the d2 itself, and cables, no audible difference what so ever
-Changed back to original OpAms and tube, still the same
-Cleaned out some dust
-Tried different power outlets
Nothing seems to do the trick. Could it me some component inside the dac gone bad? Any suggestions?
Ok, thanks. Will look into this. Maybe order some capacitors then. But which ones? Will be reading this thread for research. Maybe replacing LEDs as well, their color and intensity is a but much. My soldering skills are lower league… oh well.I wonder if you might have a capacitor going bad. Do any of the caps look bulging or different that the others. Since the hum/buzz is always there,
it seems like it could be a cap in the power supply. I have heard of power supply caps failing in the Maverick, but it has not happened to mine yet.
Without a scope, you will be on visuals, which would be my situation also. If you have a meter, check all of your jacks for good continuity. It could just be aOk, thanks. Will look into this. Maybe order some capacitors then. But which ones? Will be reading this thread for research. Maybe replacing LEDs as well, their color and intensity is a but much. My soldering skills are lower league… oh well.
That schematic is the missing link with the Maverick, at least I have never seen one. Would love to though. I have just looked atTry to follow your steps of applying changes/mods backwards and see whether you've messed up something.
Maybe something has gone bad in the process of simply changing an opamp.
Generally speaking, if the buzz is in the 60/120 Hz (USA) 50/100Hz (EU) range, it means your problem is with the power supply.
Might be a cold joint, a bad capacitor or components, a disconnected grounding chassis lug, a cable in the wrong place or whatever.
However, in order to do things properly and troubleshoot correctly you'll also need to read the schematic.
When did the buzz start?Ok, thanks. Will look into this. Maybe order some capacitors then. But which ones? Will be reading this thread for research. Maybe replacing LEDs as well, their color and intensity is a but much. My soldering skills are lower league… oh well.
I first noticed the buzz a couple of months ago. The OpAmp/Tube upgrade was done 4-5 years ago, since then I have not messed around anymore with it. So it seems the noise has occurred out of the blue.When did the buzz start?
