I have just picked up a Shure V15 type IV cart which was described as very low hours. I mounted it on my TP13A arm on my thorens td-150. I now get VERY low output from the cart with distorted sound. I am tracking at 1.25g as specified in the data sheet.
Here is what I have tried::
1) Cleaned the head shell terminals that go to the cart with deoxit. They were very dirty.
2) Set the balance to 1.25g and verified that the anti-skate was correct using an album with no tracks (blank record side).
3) swapped the two ground wires based on information found for the TP50 tonearm wiring diagram and the output of bablefish (it was in German).
4) Set the required overhang as close as I could to 49mm. The cart is a bit longer than my empire cart so it exceeds it by a bit.
5) Reseated the stylus in the cart.
6) Ensured that the connectors were tight on the cartridge pins. There is no play and they are snug.
I am pretty much stumped here. I had an empire cart on the arm previously (as in a few days ago) that worked fine. I am running the table directly into an Onkyo TX-NR901 receiver. As I said though, the Empire cart worked fine.
