Surrounds for PSB Stratus Silver Speakers
wjcjr
Does anyone here know of a source for the butyl rubber surrounds used on the 6.5" woofers of the Stratus Silver speakers (not Silver i). I had one rip a hole and would like to try to replace it myself. Any suggestions certainly welcome.
I did some looking on that auction site but didn't find anything. Tons of foam surrounds for older speakers, but no PSB butyls.
Bill C.
A hole or a tear? If its the latter a repair would probably be a better option. The Silver and Silver i also use the same woofers and tweeters. Only the cabinet dimensions (silver I slightly larger internal volume) and some x-over changes differentiate the two.
Unfortunately it's a tear about a half inch with inside of tear starting to separate from the cone. A pet mishap and yes, the pet is still alive!
Lol....about the pet still being alive that is. Replacement woofers may be available from PSB, its a Vifa PL series woofer if I remember right. Been a few years since I had one of mine out.
It used to be easy to pick up Vifa replacements but Vifa has reduced the number of 6.5" drivers it sells and jacked up the prices. Can you patch it? Try Simply Speakers but measure first. Consider eBay too. Fantastic speakers.
