Decibel_116
AK Subscriber
I am looking for some suggestions for properly gain staging this cartridge. I would prefer to use an SUT with it because of the extremely low output voltage (0.12mV). A 1 to 20 SUT would put the output at about 2.4mV, which should be fine with the correct active gain stage behind it. However, the reflected impedance the cartridge will see is slightly less than optimal. The rule of thumb is at least 10x the source impedance. This puts the minimum acceptable at 120 ohms. The SUT puts the impedance at 117 ohms. I could load the secondary side with a network to improve the matching. Has anyone else tried to optimize an SUT for this cartridge?
