What'd I say?If it's the whsh94a guy on Ebay it will be the easiest thing you ever did.
In their place, I will solder 3 bayonet sockets where the bulbs used to be.
Hence, in this case, I believe I will not need to add an additional resistor to keep the bulb from totally freaking out on me.
Connecting in series is fine, as long as you have enough voltage available. For a modern high-brightness LED with lots of voltage drop, 12V is cutting it close.Expanding the OP's scenario of 3 lamps in parallel, each with it's own resistor connected to a 12v source, would it be feasible to connect the 3 lamps in series, and just use 1 200 ohm resistor for the 3 LEDs? or don't LEDs work that way?:scratch2:
