jFF_Bulbo
Hello AKer´s.
I recently start the SX1050 restoration.
Unit was DOA, and it had several problems.. i show some of them :
AWR-104 power supply was broken, i fixed it with epoxy, patience and soldering wires point to point on the back of the PCB.
on AWM-090 protecion some resistors was blown.
In the power amp -i guess- the right bias trimpot failed and ruined many other pieces: emiter resistors, output transistors... a lot of pieces ( I HAVE NO PICS OF THIS...). Also here a stavistor had a leg broken, (right channel) i repaired it an protected w/epoxy.
All the described problems has been fixed, i recapped the unit, also many transitsors are new in both power supplies and power amp. 200+ new pieces are installed, main caps and relays are pending to install.
well. after all this work a have some problems.
1.- dc offset on right channel can´t be adjusted, it is alway about 60mv (power amp working, tested)
2.- bias ok on right channel, on the left it reaches 42V and can´t be adjusted to 50 mV.
3.- protection relay engages too fast, about 1-2-sec... soft stat relay engages inmediately.
3.- preamp is dead, no sound of any source, just a few pops and nothing more. about this, on AWR 103, i have +18v on pin 15 (should be +30v) and -30v on pin 9 (wich is ok....) so i think the is not enought voltage to make the preamp works.
4.- on AWR 103 i have +12v on pin 13-14, shold be 25v....
5.- power amp is a quit hot after 5 minutes runnig the unit.
thank you!!!!!
thank you!!!!!
