Stereoboy70
Hello everyone, I’ve got a question about an SX 5580(1050) tone board issue. This receiver has been restored and recapped Thoroughly cleaned and tested but the issue is with the tone switch. When off the receiver sounds great. No issues. When the tone switch is turned on , the R channel volume is super loud and the left channel drops a lot. I’ve checked and double checked the caps and transistors on this board. The switch was removed and cleaned with Deoxit again. Checked all of the resistors and cap orientation. Good. Wiring to other boards is good. Checked solder traces. Good. Checked flat amp
Board for any baxkward caps etc…… good. Question is why does the volume increase when the tone board is engaged? And only on the r channel?? This receiver plays and sounds fantastic until you introduce the tone board. I feel the problem exists there but I can’t seem to find it. Thanks n advance
