drmazzei
Member
I am testing a Pioneer sx-1250 and everything passes dim bulb except for the left channel. I am using a new 106 board purchased from Delta9Electronics. Rick has been very helpful and patient with me as I tested this board after installing the components. When I switch 048 boards, the "good" right board doesn't pass dim bulb when installed on the left side. Also, when I move the other 048 board to the right side, it passes dim bulb. I have tested continuity on the wires that hold the power transistors and verified that the 21193 and 21194 transistors are installed correctly and pass muster with my Atlas tester. I'm not sure what I should do next to track down this short.
