I just finished recapping my SX-1250.
I am setting the voltages following the instructions on page 38 of the service manual (Amp Board #048, Stabilizer Board #106)
I'm getting 2 volts between Pin-9 and GRND (it should be zero) on both the Left and Right Power Amp boards. The readings are erratic, but averages at 2 volts.
Turning the VR pot does not change the reading by much. I replaced the VR pot on one Amp Bd., no change in readings.
I do have 100 mV between Pin-7 and Pin-19, which is OK per specs, on the Power Amp Board (#048)
I do have 65V between Pin-17 and Pin-12 (GRND), which is OK per specs, on the Stabilizer board (#106)
I do have 65V between GRND and Pin-16, which is OK per specs, on the Stabilizer board (#106)
Also, I wonder if any of this is related to my speaker relay NOT switching 'on'. I put in a new relay, it didn't work either.
Please give me advice on how to make the 2 volts become zero and ...
Please give me advice on why the speaker relay is not switching 'on'.
If these procedures have already been discussed, please point me to the right direction.
Thanks, guys
Thanks, guys
