Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
I have a professionally serviced SX-1250 running a pair of JBL 4670s… Is there any danger of damaging the amp by running both loudness and the eq at the same time, even at high volume? I do like it loud.
.if you keep the boosting on the eq to a minimum, you will be fine.
If you hear distortion turn it down and make adjustments.
Im not familiar with the 1250 but most loudness circuits are disabled beyond 12o clock on the volume knob regardless of how much power is being pushed.
Do not think you will damage the amp if it’s run at a reasonable
level
They are 4-ohm speakers that say they can handle lots of power, 600W of music.
Here is some info on those speakers
Hello All, I'm thinking to buy JBL Pro Cinema speakers: 4670D model. Does anybody know if this is passive speaker (with embedded crossover)? Or to be used with digital x-over? Thanks for info!
www.audiosciencereview.com
I haven’t used tone controls and loudness since the invention of the CD. I used them for vinyl however.
Good luck
