Pageplayer
I've been plugging away at a 1250 recap the last several weeks when time permits.
(Thanks to MIJ_Pioneer’s most recent BOM List! HERE)
Everything was going very well until a wire broke off on AWM-089 Filter Amp Board that ran from AWG-041 Tone Control board.
I have wire wrap tools and solid core wire in the proper gage to do a factory style fix, but as I was double checking my work to make sure I connected the wires to the correct pins I noticed the service manual is stating some things totally different then what I’m seeing.
For instance, the SM states Pin 14 on AWM-089 should run to AWG-042 pin 4. But,
AWG-042 pin 4 is actually running to AWG-041 pin 8.
So now I’ve confused myself since pins 11 & 14 on AWM-089 do not have wires connected, but the manual says they both should have wires running to pins on AWG-042.
I’m curious if someone already has the actual wiring documented that could share, or could at least verify that I have proper wires connects to AWM-089?
This is basically leading into to my current problem with garbled audio coming out of the left channel.
I recapped this unit.
