Hi everyone, I revived my very sick SX-1250 using the rebuild kit sold by Peace Love and Music. This is a kit for ALL electrolytic caps, and quite a few transistors and diodes.
Good news... The Amp is fine. Both channels sound equal and clear. The phono board is fine.. both channels sound good. AM Sounds OK...
FM, is not so good. The tuner board has only 1 channel playing. Using a signal tracer, I listened to the audio out pins of the tuner board 40 and 42.
Pin 42 Has adequate volume, and the channel sounds properly through the amp.
Pin 40 has LOW volume, and can be heard through the amp, IF I shift the balance to that side and crank it up... SO, I'm convinced that something on the tuner board. This is where I get perplexed, because I'm just not that good with radio circuits. I'm certain it's something not too complex, but I was hoping that a more experienced radio tech could point me to a few test points.
I usually fix guitar amps.........so this is a bit different of territory. Thank you in advance.
