Sure. The receiver was working after replacing the resistor R4 on the power supply board. I then removed the protect circuit board and replaced every electrolytic capacitor and transistor on that board. I installed the board and the soft start relay engages but speaker relay will not engage. Do you need the exact values of each cap and transistor? If so I can provide this if it helps a diagnosis I did trace 32 v to the speaker relay, thanks
