Working on an SX-1280 and I am suspicious I may have an issue in my PS, both my + and - 33v rails are about +-36v, everything seems to work except the DC offset is slow to settle (around 100mv and falling when the relay closes), max volume on phono causes a pop that causes the relay to close, the output of the power supply also seems to be fairly temperature sensitive, blowing on it causes the regulated voltage to shift +-5mv.
I am using the following transistors:
Q1 2SD712 MJE15032G
Q2 2SB682 MJE15033G
Q3 2SC1914A KSC2383YTA
Q4 2SA904A KSA1013YBU
Q5 2SB682 MJE15033G
Q6 2SC945 KSC2383YTA
Q7 2SC945 KSC2383YTA
Diodes:
D7 WZ-320 32V, 1/2 Watt BZX55B33 .5W, 33V, 2% Zener
I did notice a small amount of oscillation on the PS output, but I'm not sure if that's just my scope or an actual issue as is only 35mv on an 80v rail.
Q1 2SD712 MJE15032G
Q2 2SB682 MJE15033G
Q5 2SB682 MJE15033G
Diodes:
