bayernfan
Got an SX-2500 on the bench and it's exhibiting some strange behavior.
Cold (amp has been off several hours) it starts fine, both channel slowly creep up to 10mV (measured across emitter resistors). It holds that value well, but once I begin amplifying a 1 kHz sine signal for longer than a few minutes, it completely loses bias in right channel (begins shooting back and forth rapidly between 0 and 20 to 30mV), and the left channel starts moving around quite a bit though not as erratically.
Once this occurs, if I disconnect the load (switch to speaker off), the right bias drops to 0mV and the left bias steadies itself again. If I switch back to speaker on (A or B), it begins the wild bias current behavior again.
I've done cursory (in-circuit) tests of all the transistors and diodes on the main amp board, including the 2SC984 transistors that strap to the heat sink. Both channels match in all tests. Checked resistors in the bias circuit as well. Both output capacitors test good (don't think that's the issue). Inspected the soldering and traces, everything appears fine.
Obviously something is heating up and becoming problematic. In the back of my mind I'm wondering if it's a trim pot on the board.
Any advice would be appreciated. It's rare that I work on a Pioneer of this type (cap-coupled).
