SX-450 tuner
Cosmic Charlie
Well-Known Member
The other day at SA I picked up an SX-450 for $10, really nice shape. I took it home and was actually amazed at the tuner section. On initial powerup the lights flickered for about 15 - 30 secs., when it settled down the FM was clean and crisp (no hiss). It picks up stations my 2 x SX-580's only dream of picking up. Is this common knowledge or do I have an exceptional SX-450 and 2 crap SX-580's. I believe they are all 3 gang 2 filter units. Just wondering, I am quite pleased. CC
I had an SX-450 for awhile, and it would pick up almost all the locals without any antenna on it... great little receiver!
Apparently both 450's I had (one purchased new, the other a curb find) were built on Mondays, as the tuners rivaled the standalone Marantz 104: lousy sensitivity and selectivity, even with outdoor FM antennas. I'm delighted that others have had better luck than me! :thmbsp:
Tom
Thanks guys, I couldn't believe how good it sounds and picks up stations. Fred you think its the power switch that is causing the flicker of the lights at powertup. It has a type of switch that I havn't encountered before. The switch is a rotary switch, which incorporates the A + B speakers w/ the on off. I think I've read here (AK) about this sw being it's achilles heel. Do you think a cleaning would help?. A replacement must be near impossible to aquire. Thanks again for your replies. I listen to alot of talk radio and figure this will help prolong the life of my SA + TX 9500's by giving them a respite from duty. CC
Charlie, the 450,550 and 650 share the same type of switch and problems.
it is a very common problem.
there are several threads detailing the disassembly of the rotary power / speaker switch, and the burnishing of the burned contacts. It takes an hour or two to free the thing up, and you will have one of two styles of switch (plastic or metal), and the plastic one could have a ultrasonically welded case. The metal one will need some VERY small screws to put back together after the rivets are drilled out.
here is a partial thread on the only METAL switch we have encountered
this is a sx-650 thread with pictures
Rabbi Rich also did a sx-450, but it was just mentioned in passing.
Thanks Mark for all the links, expessially the photos. This information will definatly help me when I get into the SX450, it may take a while but I really like the unit. CC
500th post, and it only took 2yrs. 7 months. Best site on the web, I spend more time here than all other sites combined. Thanks alot to all members and mods. Heres to 5 more years of good folks and good info and good Karma. CC
I took it apart burnished the contacts put it back together and she works like brand new. Took close to 2 hours. Thanks alot guys. much apreaciated. CC
