PapaGino
I'm having an issue with my receiver - in any stage and at any volume, theres a large crackling POP over the speakers when they are switched on. Its less dramatic when I power the unit on, and let it set in 'speaker off' for a few minutes - but there is always a pop.
Switched out many of the transistors on this unit a couple years ago, with the help of Mark the Fixer. Various diagnostic measurements look ok last i checked - I've pasted a list of what was replaced to date. Any ideas where the issue could lie?
As of May 21, 2016 - Parts list and replacements - items marked in green were replaced:
Power Supply
AWR-007 C5 220uF 50v CEA: 647-UPW1H221MPD6
AWR-007 C6 47uF 16v CEA: 667-EEU-FM1E470 47uF 25v
AWR-007 C7 330uF 35v CEA: 667-EEU-FM1V331 330uF 35v
AWR-007 C8 470uF 25v CEA: 647-UPW1V471MPD 470uF 35v
AWR-007 C9 220uF 25v CEA: 647-UPW1E221MPD
AWR-007 Q1- 2SD313- E or D: 512-KSC2073TU
AWR-007 D1 - FR2-02: 512-1N4004
AWR-007 D2 - FR2-02: 512-1N4004
AWR-007 D3 - SIBO1-02: 512-1N4004
AWR-007 D4 - SIBO1-02: 512-1N4004
AWR-007 D5 - SIBO1-02: 512-1N4004
AWR-007 D6 - WZ-320: 512-1N5257B
Main Amp
AWH-006 C1 1uf 25v CSSA: 539-SN010M025ST
AWH-006 C2 1uf 25v CSSA: 539-SN010M025ST
AWH-006 C7 220uF 35v CEA: 647-UPW1V221MPD6TD 220uF 35 Volts
AWH-006 C8 220uF 35v CEA: 647-UPW1V221MPD6TD 220uF 35 Volts
AWH-006 C9 47uF 50v CEA: 647-UPW1H470MED
AWH-006 C10 47uF 50v CEA: 647-UPW1H470MED
AWH-006 C17 2.2uF 50v CEA: 647-UPW1H2R2MDD
AWH-006 C18 2.2uF 50v CEA: 647-UPW1H2R2MDD
AWH-006 C21 10uF 16v CEA: 647-UPW1E100MDD 10uF 25v
AWH-006 C22 220uF 50v CEA: 647-UPW1H221MPD
AWH-006 C23 100uF 50v CEA: 647-UPW1H101MPD
AWH-006 C24 47uF 50v CEA: 647-UPW1H470MED
AWH-006 Q1 - 2SA572- 4B, 5A, or 5B: 512-KSA992FBU
AWH-006 Q2 - 2SA572- 4B, 5A, or 5B: 512-KSA992FBU
AWH-006 Q3 - 2SA572- 4B, 5A, or 5B: 512-KSA992FBU
AWH-006 Q4 - 2SA572- 4B, 5A, or 5B: 512-KSA992FBU
AWH-006 Q5 - 2SC1318- R or Q: 512-KSC2383YTA
AWH-006 Q6 - 2SC1318- R or Q: 512-KSC2383YTA
AWH-006 Q7 - 2SC1318- R or Q: 512-KSC2383YTA
AWH-006 Q8 - 2SC1318- R or Q: 512-KSC2383YTA
AWH-006 Q9 - 2SA720- R or S: 512-KSA1013YBU
AWH-006 Q10 - 2SA720- R or S: 512-KSA1013YBU
AWH-006 Q11 - 2SC789-O: 512-KSD526Y
AWH-006 Q12 - 2SC789-O: 512-KSD526Y
AWH-006 Q13 - 2SA489-O: 512-KSB596Y
AWH-006 Q14 - 2SA489-O: 512-KSB596Y
AWH-006 Q15 - 2SC1318 R or S: 512-KSC2383YTA
AWH-006 Q16 - 2SC1318 R or S: 512-KSC2383YTA
AWH-006 D1 - 1S2O76:
AWH-006 D2 - 1S2O76:
AWH-006 D3 - SV-4A:
AWH-006 D4 - SV-4A:
AWH-006 D5 - 1S2076:
AWH-006 D6 - SIBO1-02: 512-1N4004 (?)
Head Amp
AWF-003 C1 3.3uF 16v CSSA: 647-UKL1H3R3KDDANA 3.3uF 50v
AWF-003 C2 3.3uF 16v CSSA: 647-UKL1H3R3KDDANA 3.3uF 50v
AWF-003 C7 .47uF 25v CSSA
AWF-003 C8 .47uF 25v CSSA
AWF-003 C9 3.3uF 25v CEA: 647-UPW1H3R3MDD 3.3uf 50v
AWF-003 C10 3.3uF 25v CEA: 647-UPW1H3R3MDD 3.3uf 50v
AWF-003 C15 100uF 35v CEA: 647-UPW1V101MPD
AWF-003 C16 100uF 35v CEA: 647-UPW1V101MPD
AWF-003 Q1 2sc871 E or F: KSC1845FTA
AWF-003 Q2 2sc871 E or F: KSC1845FTA
AWF-003 Q3 2sc870 E or F: KSC1845FTA
AWF-003 Q4 2sc870 E or F: KSC1845FTA
Control Amp
AWG-011 C1 .47uF 25v CSSA:
AWG-011 C2 .47uF 25v CSSA:
AWG-011 C5 100uF 6v CEA: 647-UPW1A101MDD 100uf 10v
AWG-011 C6 100uF 6v CEA: 647-UPW1A101MDD 100uf 10v
AWG-011 C7 1uf 25v CSSA: 539-SN010M025ST
AWG-011 C8 1uf 25v CSSA: 539-SN010M025ST
AWG-011 C19 47uF 50v CEA: 647-UPW1H470MED
AWG-011 C20 47uF 50v CEA: 647-UPW1H470MED
AWG-011 Q1- 2SC1000- GR or BL: 512-KSC1815YTA
AWG-011 Q2- 2SC1000- GR or BL: 512-KSC1815YTA
Power Supply
Main Amp
AWH-006 D3 - SV-4A:
AWH-006 D4 - SV-4A:
Head Amp
Control Amp
