RyeGuy859
Well-Known Member
Hello! Ive been working on an sx-6000 that had a channel out. It was the outputs and 1 driver on the Left channel. I replaced the sanken 1080s with some 2SD555s I had pulled from a unit a while ago. That channel came up nicely and the midpoint and bias was set good. Now the other channel which was working from the start will not bias nicely. I can only get it up to around 6-7mv with the midpoint set around 34v. If I raise the midpoint closer to half my B+(73.2v) The bias in that channel drops even lower.
What ive changed in the Right channel, all 4 transistors excluding outputs. Ive checked the STV-3 and it measured 1.3v in circuit so I dont think its that either. Im not sure where to look next if anyone as any suggestions.
