I have a nice sx-626 that I have been working on but I can’t seem to get the AM tuner working properly. The output is very low. I only pick up one or two stations. The signal meter stays on 0.
While probing the ha1138 chip the AM started working and stayed working long enough for me to follow the AM alignment adjustments and get a nice strong signal from both ends of the AM band. Unfortunately the AM only worked for a few minutes before dropping back out. I suspected a solder connection so I have reflowed the AM section of the tuner board. I have also replaced the electrolytic capacitors in the AM section of the tuner board. Since some of the voltages are off on the ha1138 I replaced it with another chip that I had on hand but the voltages are the same after replacing the chip. None of this work has been able to get the AM working. Hopefully someone here can point me in the right direction.
HA1138 Voltages:
1. 11.0 volts
2. 2.75 volts
3. 11.0 volts
4. 11.0 volts
5. 4.83 volts
6. 9.0 volts
7. 1.98 volts
8. 0.88 volts
9. 0 volts
10. 10 mv
11. 0.235 volts
12. 12.1 volts
13. 2.71 volts
14. 0 volts
15. 2.67 volts
16. 0 volts
HA1138 Voltages:
1. 11.0 volts
2. 2.75 volts
3. 11.0 volts
4. 11.0 volts
5. 4.83 volts
6. 9.0 volts
7. 1.98 volts
8. 0.88 volts
9. 0 volts
10. 10 mv
11. 0.235 volts
12. 12.1 volts
13. 2.71 volts
14. 0 volts
15. 2.67 volts
16. 0 volts
