You said you changed out transistors yet I only see 2-KSA992's and 6-KSC-1845's on your BOM list, where did you change out, which boards? Did you re-check to make sure the leg placements are correct?
Control Board AWG-008 2SA572 & 2SC1000
Head Amp W21-004 2SC870 &2SC879
These can be problematic,are these the one's you changed out with the 992 &1845's. If so, again, make sure the leg placement is accurate...believe me it happens
Power Amp suggestions...thanks Mark!
q1,q2 2sc732 input 50v 0.15a 0.4w 200-700hfe 150mhz
512-KSC1845FTA (ln)to-92 ecb 120v .05a .5w 100mhz 300-600hfe $0.05 ea
q3,q4 2sc497 vas 100v 0.8a 0.6w 40-240 50mhz
512-KSC2383YTA to-92L ecb 160v 1a .9w 50mhz 160-320hfe $0.17
q5,q6 2sc497 driver npn 100v 0.8a 0.6w 40-240 50mhz
512-KSC2690AYS to-126 ecb 120/a160 1.2a 1.2w/20w 175mhz 35-320hfe $0.40
q7,q8 2sa497 driver pnp 100v 0.8a 0.6w 40-240 50mhz
512-KSA1220AYS to-126 ecb 120/a160 1.2a 1.2w/20w 175mhz 35-320hfe $0.39 (R=60-120, O=100/200, Y=160/320)
q13 2sc893 anti-thump delay 150v 0.05a 0.6w 40-240hfe 40-120mhz
The SX-1010 is ready to go...looks great and sounds amazing.
