Let's see what is triggering the protection. Using subtractive troubleshooting.
Desoldering and lifting one leg of D7 (outlined in Blue) will suppress the over-current protect triggering.
You can hit the right spot from the solder side of the board, desolder the pad and push the lead through the hole to air gap it.
It won't stop the sizzling but it will silence THAT protect input.
The protection has two badly behaved capacitors in it, C21 and C22 (0.22uf 10v CSSA). they turn into short circuits. The dreaded sky blue Sanyo "capsistor",
whose electrical leakage gets so bad it turns into a short circuit.
Normally there are 2.7k ohm resistors between them and the power output sections, but if one of those resistors has fried to a short circuit, all bets are off.
The caps (2x 0.22uF /10v ) to replace are circled in red, the resistors to test (2.7k ohm) are circled in red
the rest to be tested is circled in orange:
(4) 15k resistors
(4) 1s2472 small glass diodes
(2) 2sc1649 transistors.
ignore R50 & R51 off at the side of the board, if the power had not been stable, we could have read the voltage across them to find out the current draw for the +13v and +33v power supplies.
The transistors could be replaced. ksc1845 is the usual if you have it.
