SX-680 cap question
jermworfare
Hello all, I had a quick cap question. My SX-680 has two 42V 8000uf caps that are bulging and needing replaced, but I cannot find a replacement on Digikey or Mouser. If there an alternate size that would work as a replacment for these that you know of? Thanks!
10,000µF, 50V - should be loads of those. Physical size is important, you will want the replacements to be as near to the originals as possible, however, if they are slimmer (the replacements) you can pad them to fit the clamps. (Note: old capacitors tend to be bigger than modern direct replacements).
