SX-690 - No Output - Repair Thread - Help & Guidance Requested-Please
I don't know to be honest but I gave them a reflow there to be sure. No change in voltage at pin 41
Ok I popped out 2sc1384 and replaced with ksc2690, just because I have a bunch. Will I take voltages of that?
E= -0.56v
C= 350mv
B= 122mv
That's DMM positive to test point and negative to chassis
It was open circuit!! I had to wire 3x 100 ohm resistors together, now there is music. Thanks Pete! The volume rises and falls though and crackles like crazy. I'll get the stk voltages again now?
Pin41 is now at 38.69v
music will maybe most likely play fine now on full mains ... on dbt the voltage will drop lots when turning up the volume .
to be sure everything ok in relation to the resistor going bad measure voltage right across it ..it should measure about 1.4v if all good .
Thank you so much for all your help Pete, i will check that tomorrow as you have asked and i will post the results, including those at the stk's.
I have to leave the unit for the night now. I will order that replacement resistor too.
Just wondering how you went. So the issue was a faulty resistor then ?
Q402 was ok, but you decided to replace while you had it out ?
You think your STKs are still the originals?
I will be doing a re cap of my 690 soon.
I'll post up my measurements before and after as I proceed.
As I mentioned before, one of my STKs are toast and have purchased aftermarket units.
The unit plays fine but only on one Channel for now.
Hi There, had one SX690 in my workshop today. Failure: No Sound on both channels. All Fuses OK, STK's did not have short outputs. 1. 24V was not feed into Power amp due to a burned Resistor. (easy to find with Schematics.) After recovering 24V big hum at outputs on all 2 Amps. Switched off. 2. Found defective 100Ohms Resistors (2 on each STK) green in colour. All 4 no Ohm readings. Had problems with green Resistors 1/2W in the past. After replacing 4x100Ohm and one 27?Ohm for 24 control Voltage all OK. Hope this helps. Cheers, Oliver
