I'm finishing up a recap on a 727. I've replaced all the electrolytics on the PS, protect, and all audio boards. I also replaced the usual problem transistors while I was in there. I did not replace Q1 and Q3 (2SD313D) on the PS board - AWR-010. I don't have anything on hand to sub for those. The board doesn't look like it's been running too hot. Only a very slight discoloration under R9. The previous owner must have treated it well and not shoved in a cabinet.
Would you go back in and replace the the two 2SD313e and/or R9 (330/2W)? The KSC2073 has been used in the past - and they're only $1.00/each
