Christa
Hi all!
I'm working on recapping a receiver and its my first complete refurb project. I'm a complete novice - prior to this I've repaired an a faulty phono input SX-525 by replacing a few transistors, replaced the lamps and cleaned the pots, but that's about it. I actually started on this SX-727 a few years back but I gave up due to shoddy solder skills and equipment. Just updated my equipment - got a good soldering iron, got quality solder and flux, a simple desoldering pump, good test leads, nice helping hands - and what a difference! I was using just a desolder wick and a radio shack soldering iron before and it was a mess.
In 2017 I packed up the SX-727 in the original box (without the case) and put it in the back of our storage room. In the intervening years a mouse made a home inside the amp - right behind the tuning dial. It ate through the tuning dial cord, chewed up some wires and generally made a mess. I figured since I had ruined it, I might as well practice my soldering skills and give it a go. First, I restrung the dial cord then fixed the wires and cleaned it all up. I have replaced all the capacitors on the AWR-011 Power Supply board and the caps and all of the transistors on the W21-002 Head Amp. Hooked it up to my homemade DBT and then to some speakers and it sounds good! Still have some scratchy pots - but that's to be expected since it was a home to Mr. Mouse for a few years. I'll be cleaning all the controls with deoxit/faderlube.
So my main question for you experts is moving forward - I'm going to go through the service manual tonight and read all of the voltages and adjust the bias. Assuming I can get good results I'd like to finish the refurb, but I'm concerned with replacing too many parts and affecting the sound. I know that all of the electrolytic capacitors need to be changed, but should I also be replacing all of the transistors or just the noisy ones? Also, I was thinking of leaving the tuner board alone - it works well now and sounds good, but are there known problematic parts that I should replace? We listen to a lot of music so I'd like this to be our main amplifier if I can get it up to snuff and I'd hate for a night to be ruined with a bunch of crackling or worse.
Sorry for such a long post, but thanks for reading!
