Today I had my SX-727 outside on the patio and adjusting the Bias und DC Offset after some work on the Head Amp Unit W21-002 and the Protection Board AWM-027. After the adjustment I had a successful DBT-test.
We had some high temperatures above 86 °F and the open unit was sitting in the bright sunlight for 2-3 hours.
Later, but still hot when starting a listening test with tuner and speakers connected, I had intermittent failures on one channel, either on the right and sometimes on the left sides in Stereo mode. Quite irregular.
Switching to Mono didn’t help as well, the failing channel stayed for some time.
My first idea was the Head Amp Unit W21-002, but that wouldn’t explain the missing channel in Mono.
After the outside temperature dropped below 80 °F, both channel work fine.
I hope it’s not a stupid question, but what part could be so heat sensitive?
Has anyone had already a similar experience?
