CaptainNemo
Hi everyone,
First of all, I love how helpful the AK community is here. It's amazing!
I got this SX-780 that had fading sound/ channel dropping sound. I recapped it using the list I found on this forum. All is good, i test it and it sounds good. I put everything back together and now it powers up normally, I hear the relay click after a few seconds but I have to turn the volume know 80% to barely hear an FM radio station. Same thing for Phono. Unfortunately, I haven't found any thread discussing this particular problem and since i'm an amateur electronics guy I couldn't figure it out myself.
Few things I've checked are :
Fuses: took them out and read 0 ohms - which i believe should be OK.
Darlington Powerpacks: Voltages seem to be good according to another thread.
Soldering and caps look good, no detectable problems
Any help would be greatly appreciated! I do have a DMM but I'll probably require a quick explanation how to check some parts, if need be.
Thank you so much.
Thank you so much.
